pulpwood007's avatar
pulpwood007
Refrigerator cooling question
I have followed all the threads involving improving cooling on RV refrigerators. My Norcold is a constant problem to keep the temps at around 40 degrees.
My question is in regards to installing additional fans, both blowing across the coils and inside the fridge to circulate the air. There are controllers sold to only activate the fans when the refrigerator is running (in the cooling mode). They turn off after the cooling cycle is complete.
Other folks just simply install fans that blow across the coils, and circulate air inside the fridge and control them manually. Either leaving them running continuously or turning them on when the fridge will not maintain correct temps.
Are there any issues in letting the fans run continuously? Less efficiency?
  • Running the fan all the time uses electricity. But if you have lots of power, that's not a problem.
    Here is another idea -- this should increase the efficiency of the airflow. It's a flue deflector:
    Flue deflector -- DIY
    It should reduce (or in my case eliminate) the need for fans to improve airflow.
    Good luck!
  • They will get dirty in many cases and fail.
    Have you looked into the ventilation? Most rigs do not have refer installed with clearances as specified in the installation manual.
Having RV issues? Connect with others who have been in your shoes.24,314 PostsLatest Activity: Sep 09, 2025
