ib516
Apr 22, 2014Explorer II
j-d wrote:
Without your saying what kind of fridge, most newer ones have a thermistor mounted on the cooling fins in the fridge compartment. It leads to terminals on the control board. If it is disconnected, removed from the fins, wires broken or terminals corroded, the control board will interpret that as needing to keep the cooling unit running.
I had the same problem, and the above was the cause.
In mine, there was a big white plastic clip, (about 4" tall and 1" folded over each side of one of the cooling fins) that is supposed to hold the temp sensor against the aluminium fins in the back top portion of the fridge. The clip was still there, but upon closer inspection, the temp sensor and wire had fallen out from behind the clip, leaving the temp sensor hanging from that single white wire.
Reattached the sensor by removing the clip, slipping it inside the clip again, and placing the clip back on the fin.
If you look closely, you can see the white wire leading up to the clip under the red circle in this picture.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
