dougrainer
Feb 17, 2014Nomad
Check on a Dometic has 1 function and 1 function ONLY. It means that the refer wanted to run on LP and it did NOT light on LP. Either there is air in the lines---run about 10 on and off cycles on LP to purge the lines. The Gas is OFF. The manual gas valve on the back of the refer is OFF. The ignition sequence on the refer is malfunctioning. Doug
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
