wa8yxm
Feb 17, 2014Explorer III
Suspect list:
Do you have PROPANE
Is it turned ON
Does the range top work
If so try again with the fridge at least 3 times
Have you done the recommended routine maintenance on the fridge burner?
if not do so and try again
Problem that you will need to throw money at: Bad solenoid (But you heard the click so I think not) bad ignition system, bad flame sensor bad control board.
Oh, and low battery voltage (move that to right after Propane tests.
Do you have PROPANE
Is it turned ON
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
