Almot
Feb 17, 2014Explorer III
If you are not hooked up to 120V, try running it in "gas" mode, not "auto". And go through the checklist suggested above: is there gas in the tank, is the valve on tank open, purge the air if the rig is new. Keep in mind that "gas" mode usually (in 99% of new RV frigs) requires 12V battery present.
If you are hooked up to 120V, run it in "Auto" and give it 5-6 hours. These frigs are slow. If after 5-6 hours the temperature in either freezer or fridge chamber doesn't drop from where it was, then there is some problem.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
