MFL
Jun 17, 2017Nomad II
Chris Bryant wrote:
If it is in a slideout, with 2 sidewall vents, it needs the fans, and if they are not running, it will not cool nearly as well.
The thermistor will adjust the temperature a bit- slide up for colder-
Moving the sensor up/down does not make more than a few degrees difference. With the fridge in the slide, the fans will make a big difference. With no fan running, fridge will run warm.
Jerry
