SidecarFlip
Jul 04, 2017Explorer III
BJean wrote:
Just found this and as I am having same problem what is best way to check
the temp switch?
Temp switch? There isn't one. The Thermister controls the temperature function. That is the thing attached to the outer (left) fin on the evaporator inside the fridge if thats what you are referring to.
You can upgrade to an adjustable one (snip the tip) if you goggle that, but the Thermister either works or it don't.
Your problem is??
