dougrainer
Jul 05, 2017Nomad
pnichols wrote:
That "sliding of the thermistor up/down on the cooling fins trick" raises a question.
Does changing the position of the thermistor adjust both the freezer and refrigerator sections' temperatures up/down together ... or does sliding the thermistor adjust only the refrigerator section temperature up/down ... or does sliding the thermistor instead adjust the amount of cooling that is allocated between the refrigerator and freezer sections?
The reason I ask is our RV's Norcold refrig works just fine with no fans, however the refrigerator section averages 32 to 35 degrees (a bit too cold) and the freezer section averages 10 to 15 degrees (a bit too warm). I'm wondering if sliding the thermistor will change the ratio of cooling allocated to the two sections so as to maintain the refrigerator section average temperature around 38 degrees and the freezer section average temperature around 0 degrees?
The Thermister has NO relation to the freezer. The sliding of the Thermister is ONLY for AUTO temp refers. Auto temp refers have NO adjustable tstat. So, sliding the Thermister up and down will change the preset by only about 4 degrees max. The freezer will get to its lowest temp regardless of the Thermister setting. If your refer is 32 to 34, then it is suspect that your Thermometer is not accurate if the freezer is 10 to 15 degrees. The freezer specs are 10 degrees or LOWER. Has the Cooling unit been replaced and how old and what brand/model is the refer? Doug
