pnichols
Jul 06, 2017Explorer II
buylow12 wrote:
If it was blocked though wouldn't the refrigerator be warmer not cooler?
I don't know anything about how your Norco works but generally you slide the thermistor up for colder and down for warmer. Just slide it down and see what happens. I mean what's the worst that can happen? That it does nothing?
Thanks!
From what I have read in these forums over the years concerning RV propane refrigerators, we are one of the fortunate ones to have an excellent refrigerator so far. I has always served us well in high or low outside temps and when partially full or full. I just want to tweak it for better balance between the temperatures in both sections. As I said earlier I haven't called Norcold yet but from what you say above, probably just sliding it's thermistor down a bit on the fin will give me a refrigerator section averaging close to 38 degrees while at the same time a freezer section averaging close to 0 degrees if use a temperature switch position of 4 or 5.
