foodog2's avatar
foodog2
refrigerator not working
I have a 2005 Gulfstream class c and I went to use it this fourth and had some issues with the fridge. Seems it only runs on propane and not on wall power. Any ideas before I take it to the repair man. I have the good SAM maintenance plan but if its a under 500$ fix I would rather do it myself. I do a lot of dry camping so a, not sure when it stopped working, but it works great on propane.
  • Funny it is now working. I turned it on this morning and it never cooled after several hours. When I had the back cover off, I removed and replaced every plug and connector on the board. After 3 hours it is frosty cold the propane is turned off. Maybe a dirty or loose connector was causing a low voltage. The only other thing I changed is the engine battery.
    Now to get the generator working. Hopefully thats just a carb rebuild.
  • Funny it is now working. I turned it on this morning andIt never cooled afyer several hours. When I had the cover off I removed and replaced every plug and connector on the board. After 3 hours it is frosty cold the propane is turned off. Maybe a dirty or loose connector. The only other thing I changed is the engine battery.
    Now to get the generator working. At least there is a generac dealer down the street and I can avoid the rv shop.
  • FoodDog,
    What is refig doing (or not) to make you think it's not working on power v gas? My Dometic cools faster and better on gas but short of tech-ing the heater coil I would be hard pressed to tell if it's "working" on power unless I waited hours to see what temp was.
  • Bob, so I do check the voltage out of the board to the element? Or at the element? Thats easy enough.. I asssume the element is behind the cover where the gas lines are. Hard to sell without a working fridge :)
  • Before you pop for a new board, check to see if you have 110/115 volts at the terminals going to the heating element. If so, he element needs to be replaced.
  • Its a dometic and the fuses are good on the back of the unit. Seems like that card is the only think that could go bad. And the coach batteries are new. I will jave to see if the manual has the voltages. I know I touched one side of the fuse and got shocked.
  • A couple of possibilities come to mind. Either the electric heating element is bad or the control board itself. Is it a Dometic refrigerator? If so a new Dinasaur control board runs around a hundred dollars. If you have experience with a multimeter you can troubleshoot the problem at the back of the refrigerator on the outside of you class C.
    Gary S.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
