dougrainer
Jun 28, 2016Nomad
MEXICOWANDERER wrote:
4.4 lbs per gallon. A 20 pound pot is filled to 85. Better refactor your calculations. Check OPD valve data. Four gallons and small change for fourteen dollars. I've never encountered an RV refrigerator that cooled as good on electricity any electricity than it did on LPG. I even tried tweaking my regulator to 13" water column which helped a little on gas. Electricity cooled new Nor-cools to the low 60's while gas minimums were high forties, low fifties.
Drilling out burner orifices was a waste of time. Overheated the burner chamber.
The reason you believe this is because you do NOT have the experience to state what you stated. ALL my tests when fixing refers(thousands over 37 years) is based on 120 operation. The only time I test on LP is if the customer has a specific complaint on LP. You may be an electronics genius, but NOT a refer expert. Your last sentence tells it all. Doug
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
