BennieH wrote:
Doug, the LP burner does have a higher but output. I can monitor my boiler temps with my ARP and on LP the boiler is abou 20 degrees higher. That will change the cooling output.
So, 37 years as a trained expert means nothing to you people:h Then lets just UP the LP pressure and get that boiler temp up 30 or 40 degrees higher. Then the refer will just be a sub zero miracle. Just because YOU are monitering the flue temp on LP and electric, That higher temp does not mean LP is better. The Makers of the Refers KNOW what the parameters should be. If they felt that 120 should be higher, all they have to do is install a slightly higher wattage 120 element. As I mentioned, Do you also monitor the 120 voltage when you take those ARP measurements. Is the voltage at 120 or higher? When testing is done for Service or warranty, Dometic and Norcold do not state to use LP only for testing. They want whatever is available which is 120 in a shop. They NEVER state after giving them the results (bad results), OH, do it on LP and then call us. Doug
