Grey_Mountain's avatar
Sep 20, 2017
Refrigerator Recycling
Just noticed something having to do with my refrigerator is recycling at (estimated) 5 second intervals. It still freezes and cools.
This just started after my last trip about a month ago.
Any ideas what could be the cause of this?
GM
  • If it is in a slide out, with a top side vent, allowing access to the top, outside condenser fins, it is easy. Otherwise, the unit has to be pulled.
  • That is the fans running. If it is cycling quickly, I would bet the thermal switch on the condenser fins is bad.
  • NORCOLD 1200LRIMD
    Both Electric from shore/generator or propane.
    Recycles on both sources.
    Just noticed that if I open the door, it stops.
  • j-d's avatar
    j-d
    Explorer II
    Grey,
    Make and Model of this Fridge, please.
    I trust it's a Two Way RV Fridge that works using LPG or 120 Volts AC from Shore Tie or Generator.
    Is this cycling on LPG, Electric, or Both?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
