Second_Chance
Mar 15, 2019Explorer II
Do other LP appliances (furnace, stove, oven) work OK? If the issue isn't the cutoff valve on the frig, has there been any recent work on the LP system such as replacing a regulator, etc? I recently replaced the auto-switch-over regulator and had to bleed the air from the LP lines before everything operated correctly. I did this by lighting all the burners on the stove for a while (it's the farthest LP appliance from the tanks and regulator). After a few re-lights, everything works fine, now.
Rob
Rob
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
