Old-Biscuit
Mar 15, 2019Explorer III
Check light is triggered when flame fails to light/fails to PROVE it lit
1st thing...
remove burner/orifice and clean them
Soak the orifice in alcohol and then blow it out (LOW air pressure---NO poking ANYTHING thru orifice ---you will damage it)
Often debris/bugs even spider webs collect during periods of non-use so burner cleaning is 1st thing to do when not lighting off (furnace/water heater etc)
If spark electrode is NOT making a spark then you need to do more investigating/testing
Posting the MODEL of your fridge would be helpful for specific info
1st thing...
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
