zell66's avatar
zell66
Refrigerator runs on A/C but not LP
I have a Dometic unit and it runs perfectly on A/C but refuses to ignite on LP. According to manual I have tried restarting fridge 3 to 4 times but nothing. Yes LP tank is full. lol
Any Ideas???
  • Mine had the same symptom last fall. The burner orifice was plugged so I took it off and blasted it with carb cleaner and all was good.
  • DrewE's avatar
    DrewE
    Explorer III
    At least some Dometic fridge burner assemblies have a manual gas shut-off valve at the gas solenoid assembly. It looks like a large set screw, not so much like an obvious valve, and turns a quarter-turn from on to off or vice-versa. (It may be behind a sheet metal shield around the burner area.) If this is closed, opening it will certainly not hurt the situation. This is hardly the only thing that can cause non-operation on gas, but it is an easy one to check and fix if needed.
    Here's a random picture from the internet showing the assembly (with various covers removed); the shut-off valve is just underneath the orange rectangular solenoid gizmo. (It's the one with the slotted head on the left, not the inset hex key one on the right.)
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
