dougrainer
Apr 01, 2017Nomad
I have NEVER had a Main control board cause Cooling problems or freezing problems. Are you positive he connected the temp Thermister back correctly and IS connected to the board. I do not understand why ANY so called RV tech would install a USED part on a customers coach. NOT professional and I would NEVER use such a parts changer again. You then have TOO many variables that may cause a problem. Maybe the Board is NOT correct for your refer. Maybe he did something wrong besides using used parts. Doug
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
