dougrainer
May 28, 2017Nomad
You still have the 1996? If so, LOOK at the rear control board. If all the circuits/resistors and such are encased in beige/yellow epoxy, the problem is the control board. Replace it. If the board is greenish epoxy then more testing is required. The OLD Dometic boards from about 1993 until 1998 were defective. Intermittent check light was the symptom. It could NEVER happen or it may be hours/days/weeks before it happens. In your case 20 years. Doug
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: Apr 05, 2017
