dougrainer
May 28, 2017Nomad
Flyfasteddie wrote:
I had similar problems a few years ago with my 1991 fridge. Everything else was fine but I would have random shut-offs on propane.
I replaced the board and not only did the problems vanish, but in a situation where a strong wind does blow the flame out, the Dinosaur board is smart enough to turn the fridge back on after 30 seconds or so, rather than just shutting down until you manually reset it (usually after being gone from camp for 8 hours)
The fridge also has much cooler and more consistent temperature control than it ever did with the original board. It was highly worth it for me.
The BOARD has no affect on cooling reliability and consistant colder temps. ALL it does is turn the Heat source ON and OFF, relying on the Inside Temp Sensor. Now the 30 second restart by Dinosaur is a neat feature, but it is extremely RARE for outside wind conditions to blow out the flame. Doug
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: Apr 05, 2017
