StephJohn2010
Oct 18, 2013Explorer
Learjet wrote:StephJohn2010 wrote:
Just a quick question: Does a campground have the ability to fix a 'high voltage' situation coming from their 50 amp shore power or is it out of their control (aka is it the power companies deal/problem)?
What are you calling high?
If you are on 50 amp you could be seeing a problem with your, or the pedestal neutral connection. This would cause you high voltage on one leg in your RV. This can be very very bad.
Ok. So how do I test the neutral connection on both?
