DryCamper11's avatar
DryCamper11
Remote water pump switch - latching relay?
I want to install remote water pump switches that operate a latching relay to turn the pump on/off with a single press of a momentary contact switch. I'm tired of being out in the boonies and getting a piece of dirt in the pump or a leaky faucet and having the pump BRRRP every couple of hours at night while trying to sleep. I don't want to turn off the master pump switch while sleeping (which I could do now) since I don't want to walk to that switch each time I want to use water, so I need remote controls at 1) the kitchen, 2) in the bathroom and 3) in the outdoor water compartment.
I've got the momentary switches, 4 conductor wire and LEDs for pump ON/OFF display, but I need to buy a latching relay. The relay has to be zero power in both on and off states. A ratchet type relay is preferred. I have a double relay - two DPDT relays that mechanically interlock so when one fires, the other changes state, too, and vice-a-versa. Unfortunately, the relays are 120AC, so I'll have to rewind the coils. I'd prefer to buy one that's 12VDC and is a single ratchet type.
The pump is 5.5 amps, so I need about 10A DC capacity for the contacts. Does anyone know of an RV system like this sold commercially where I can just buy the relay part? I can probably find one at Grainger's, etc. but perhaps someone else has built this before and has a relay number. I've found some latching relays online, but can't seem to verify that they use zero power in both states (they may latch with power - it's hard to tell).
Any suggestions?
Thanks!
  • Use genuine TYCO relays, not junk alternatives and this puppy will last you 30-years. And you don't need to return to Mickey Mouser if it doesn't. Any Bosch type relay will do in a pinch. Means any part store has them. But I've not seen a TYCO blow up.
  • OnaQuest wrote:
    The Intellitec Monoplex Controller has less than
    2 milliamps standby current. Your batteries loose more charge, just sitting totally disconnected, than that. I doubt very seriously that the average RVer caries a meter that will detect, much less measure, that.
    I thought that as well, but then realized that while the standby current is negligible, they don't give a working current- while the pump is on (but not running). I suspect that it is holding a relay closed, which would draw more current. I could be wrong though- they do use latching relays in other applications.
  • DryCamper11 wrote:
    Chris Bryant wrote:
    Intellitec water pump controller- single wire to switch (which just grounds). Why reinvent the wheel.
    Thanks for the suggestion. To avoid reinventing is why I asked. That claims "Negligible standby current", which means it's not what I'm looking for. There's no reason to have any standby current.
    Also, the DEI 611T Relay Timer is an option, but again, it's solid state, and I'd rather just have the mechanical ratchet type. The solid state devices are more sensitive to spikes and other misc. issues found on an RV 12V electrical system.
    Get real!
    The Intellitec Monoplex Controller has less than 2 milliamps standby current. Your batteries loose more charge, just sitting totally disconnected, than that. I doubt very seriously that the average RVer caries a meter that will detect, much less measure, a current that small.
  • wnjj's avatar
    wnjj
    Explorer II
    digikey
    I changed the range hood switch to SPDT and added a 2nd switch in the bathroom. That isn't real practical for 3 switches or if you can't run the wires but it's low tech and zero power.
    I too wanted to turn the pump on from the bathroom for night visits or just stopping along the roadside.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
