RJsfishin
Nov 10, 2014Explorer
I also left the old converter, just disconnected the ac input, and connected those same wires to a new receptacle for the new "stand alone" converter to plug into. This is all fine and dandy, if you have room for a new stand alone converter. If not, you may be forced to go w/ the change out kit converter, like a 4655 I think it is. In that case you will be removing the old converter, which is usually in the bottom section of the electrical panel.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
