gregwest's avatar
gregwest
Remove silicone from calking
I went on the roof of my RV, as one window leaks inside, to see if there were spots where water could be getting in.
Some of the grey calking around the seams, vents etc. had cracks. Without knowing, I coated these cracks with clear silicone.
What is the safest way to remove the silicone from the calking? Some silicone is on the roof cover (rubber I believe - white roof).
Some say to use mineral spirits and elbow grease...But with groves in the calking I find this may not work as the silicone is in the cracks.
Hoping someone has a solution...
Also, if I do get the silicone removed (my guess it all will not come off), what is the proper calking to apply to seams, roof vents, antennae etc.?
thanks,
Greg
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
