mrgreetis's avatar
mrgreetis
Removing a circuit breaker
In my TT I have a WFCO converter with its associated breaker/fuse panel. I want to add another breaker for a new converter, but as I was looking, I could not see a way to remove an existing breaker. I had the cover removed. I could see the lip to hook the new breaker over and the contacts for the supply. But, I couldn't see how one would pull one.
I know it is probably something simple, but I didn't want to start prying and crack one of the existing breakers.
Any help would be appreciated. Thanks in advance.
Mike
  • I agree... if you are this inexperienced, you really need to be shown by an expert. You just can't mess around with that much amperage and not know what you are doing.
  • Have you pulled off the front cover so all the 120v wires are exposed?
    (do unplug first)
  • If adding a new breaker why the need to remove an existing breaker????
    With ALL power OFF
    Disconnect wire from breaker terminal
    Pull out on top of breaker
Having RV issues? Connect with others who have been in your shoes.24,297 PostsLatest Activity: Aug 09, 2025
