Fisherguy's avatar
Fisherguy
Removing Eternabond
We have an 07 Komfort, it looks like the factory used Eternabond ontop of the slides that I think should be replaced. I know this stuff is super sticky, what's the best way to remove the old stuff so I can replace it?
Here's a pic
  • I have found that "hot" solvents like acetone, work the best it is recommended by Eternabond. I have used it and it has worked out very well and have yet to have any problems with it not sticking and staying that way for over 10 years.
  • Ok thanks guys.
    What's the best cleaner for the rubber roof before applying the Eternabond?
  • X3 heat gun plastic scraper.
    You don't need to get all of the stickum off. As long as it is clean the new tape will stick just fine.
  • A hair dryer or heat gun, on low, and a plastic scraper.
    Some use an oscillating tool.
    I used a heat gun and plastic scraper. It did a good job. Take your time.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
