GwdToday's avatar
GwdToday
Removing Generator from 1991 Allegro Bay
Does anyone have know how to remove the generator from a 1991 Allegro Bay motorhome??? There is no slide out or anything and it does not look like it will come out without removing something.
  • What type of gen dies it have. Gen should be setting in its own tray should have 4 bolts holding it. I wouldn't think it would be you rubber isolator bolts. Look under trailer where the gen is.
  • Patrick,
    If you continue to have a problem, call Red Bay and ask them how it was installed. They made the coach and they are very proud of what they build. I believe the owner is named Bob Tiffin and he will talk to you if you ask. He has taken the door off his office to show he really has an open door policy. Just because you have an older rig doesn't mean they have washed their hands of it.
  • There should be 4 bolts on rubber mounts, the wiring, the fuel line and the exhaust. I have used a wooden ramp to slide them out in the past. What kind of unit is it and what's the problem? Many repairs can be done with the genny in place. Good luck with your repairs. By the way, welcome to the Forums!
    Miles
  • You might search around the site as somone had a question before but I'm not sure without a sliding tray. I suppose its just bolted to Lord mounts.
