loggenrock
Aug 29, 2016Explorer
Ours has stainless steel wheel "simulators" both front and back. These are held on just like a car hubcab - spring steel clips inside the edges. Easy to work with if you spend about $15 and get a "hubcap tool" online - part pry bar (bent at the correct angle) and part rubber mallet to replace them. I also added 2 zip-ties 180 degrees apart, since the Sprinter wheel is the style with MANY holes - just laced the zip-tie thru. No "structural", but in the event one began to loosen, this will keep it from flying off immediately.ST
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
