- theoldwizard1Explorer II
pianotuna wrote:
Hi All,
I'll be "feeding" the unit with #8 wire.
I have a choice of powering from the alternator, or powering from the starter battery (which is of course charged by the alternator), but only with the ignition key turned on. Doing the battery route would eliminate surge on the alternator, so I'm leaning in that direction.
You are OVERTHINKING !
#10 wire is more than enough (I always recommend pre-tinned marine wire - no corrosion).
You want an input that turns off when the key is off. Don't worry about surges. The charger will prevent that. - pianotunaNomad IIIHi BFL13,
As the #8 is already in place both for input and output, moving up in size before I try it seems a bit silly. I'll certainly let you know (after Cdn Thanksgiving). - BFL13Explorer II"Rated Max power is 250 watts."
Yes but what is that rating based on? 20 amps output means 250/20 = 12.5 volts.
You can choose a charging profile that is 14.7v at 20 amps = 294w.
That is what it is supposed to do, never mind its "rating" of 250w. I have no idea why they have that in their specs. It is like those converters that are "rated" for when they are at 13.6v and not when they are at 14.4v. Some kind of "Sales" stuff maybe, who knows?
Meanwhile you can install it and see if it holds 20 amps steady when set at 14.7v. If it does, you are good. If not, you will have to use fatter input wiring or use the frame until it holds its 20a.
Also when they specify the output wiring they seem to forget that the batteries also have some resistance, not just the wiring. So you might have too much voltage drop between Renogy output and battery post voltage when you measure each in real life. IMO use your #8 for the output and #4 for the input and hope for the best.
You won't really know until you install it and try it out. Measure everything and be ready to adjust the installation as required. - pianotunaNomad IIIThe owners manual suggests #8 wire is good for up to 20 feet for the 20 amp dc to DC unit. Fuse at 30 amps. ANL type
Output wire is #12 for up to 10 feet. Fuse at 25 amps. ANL type.
Input voltage is between 8 and 16 volts.
Efficiency is 90% (excellent). - GdetrailerExplorer III
Lwiddis wrote:
That’s terrible efficiency! Thank you for posting.
Re read my post.
It looks bad, but in reality it isn't as bad as you may think.
If you use watts as part of the conversion you will notice that watts will be pretty much the same other than the switching power supply efficiency which can be as low as 85% and as high as 92%.
for instance 12.0V at 30A is 360W
If you convert to 14.0V at 360W you get 25.7A at the output not including the switching power supply loss of say 15% which would be about 3.9A, the result is 21.8A available at 14V...
Converting the voltage up drops the amps of the output but the watts stay the same. It is the principle behind why utility companies use massive transformers (which waste a lot of energy) to boost the power plant voltages up for transmission then convert the voltage down to your household voltages.. Without that conversion they would need to string even bigger more massive wires on the poles..
Does that help clear it up a bit? - theoldwizard1Explorer II
CA Traveler wrote:
Not very efficient. :(
Wonder if it varies by voltage or amps.
I am betting it does !
Comparing just amps is not fair. You have to look at power which is watts which is amps TIMES voltage. - BFL13Explorer II
85% is typical for converters and chargers so not "terrible" at all.
Plus the "efficiency" of a solar controller varies with how much buck or boost it is doing, so I am guessing it is the same with the DC-DC units of whatever brand. Although solar controllers are in the 90s % not the 80s like converters. - LwiddisExplorer IIThat’s terrible efficiency! Thank you for posting.
- BFL13Explorer II"The whole idea of the dc to DC is to boost the voltage going into the battery bank. Therefore voltage drop to the charger doesn't matter--so long as the ampacity of the wire size is not exceeded."
Yes it does matter.
The unit is "buck/boost" and the output voltage will be higher than the input's in many situations so it has to boost. The voltage drop to the charger is vital to keeping the input watts high enough to keep the watts up. It also affects the amps draw on the alternator, which you want to keep as low as possible.
I had a problem where my output amps fell off from 20 and it turned out the input voltage was too low. The unit has a boost spec from about 8 volts but not quite so in real life. Anyway, you improve your input voltage "somehow" until the unit can sustain its full output amps at the chosen output voltage. You cannot control the input amps directly.
I am using the thin and long positive wire in the 7-pin as input so to get the whole circuit better, I had to swap over to using the frame instead of the neg 7-pin long thin wire. If that had not worked, I would have had to run a fatter positive wire too. - pianotunaNomad IIIBFL13,
#8 has a voltage drop of 2.46% at 10 feet (more than I need). It can carry 55 amps.
On the Output side I might have about a 4 foot run. Voltage drop about 0.76% with #8 wire at 20 amps. Pretty much I think that can be ignored.
I must look up the charging voltage on the telcom jars that have served me so very well.
Thanks for the thought provoking comments.
Having RV issues? Connect with others who have been in your shoes.24,232 PostsLatest Activity: Apr 10, 2025
