LittleBill
May 04, 2022Explorer
BFL13 wrote:
Does the AH counter not work right to say how many amps down or back up it is wrt zero ( as zero was at the last reset) ?
Ah counter works fine, and is accurate, but the larger 100% is deceiving, which appears to be based on voltage alone. there is no setting for amperage. only ah high and low voltage. should have been trivial to add it in, but its a miss.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
