Microlite_Mike
May 05, 2022Explorer II
BFL13 wrote:
The R manual suggests you can "zero" (as I call it) the AH counter by either draining the batt to zero or doing it when the batt is full. How stupid is that???? :)
This is another example of "advantage Victron".
A "Zero Current" calibration is as easy as disconnecting the negative cable from frame or negative bus then using zero current cal feature on App or meter itself.
Between adjusting Peukert Factor battery capacity in setup I've found my Victron to be extremely accurate when comparing the Ah use shown on meter (or app) after a set time with a known load.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
