BFL13
May 12, 2022Explorer II
I did set capacity as 200AH and voltage as 14.7 and left the other parameters blank for now.
On recharging with the charger set to 14.7, the monitor gets to where it shows the batt reaching 14.6v and amps are down to under 1 amp and the batt picture has risen back to 200AH.
It is not up to 14.7v yet on the monitor (might be set at 14.6 on the charger, hard to tell exactly), but is where the batts are Full by specs. With the Tri, I would now reset the AH counter to Zero and drop the charger to eg 13.4 Float and walk away.
With the Renogy I have no clue (yet) so I just drop the charger to 13.4ish, but no idea if that 200 will be seen again after another down and up.
Is that battery attenuation setting for charging efficiency? Another mystery. That would affect estimated SOC if so.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
