KJINTF
Feb 28, 2021Explorer
Not sure about the wiring of the Renogy but would assume it is similar to my Victron 12-12 Orion-Tr 30amp. The "-" connection to the source and load are isolated on the device, however can be connected together and do get connected together when the source and load share a common "-" ground.
Question for you guys
Anyone find a way to adjust the output/load current of a DC-DC converter?
Temporarily lowering the charge voltage does the job but is not as "clean" as desired.
The Bluetooth app does not offer any current adjustment that I can find only a custom voltage charge profile.
I charge a 200amp LiFe four cell prismatic home brew battery which will easily take the full 30amp from the DC-DC charger thus consuming 40+ amps from the source. My desire is to throttle back the charge current at times when the solar is not doing enough to keep up. The solar charges a 200amp PB battery bank. Don't care if it takes longer to charge the Li. I do not want to see my Pb bank get discharged while charging the Li bank. Yes I understand I could set the source cut off voltage high enough to eliminate the possibility of too much discharge but again it is not a "clean" solution and would cause the cycling on/off issue.
