StirCrazy
Feb 28, 2021Moderator
BFL13 wrote:
With it finally working, with the truck running, I had 14.3 volts in the truck and 10.87 volts back in the camper at the DC inputs! (DC-DC will work down to 8 volts ISTR) That was using the 7-pin wires and no idea what the amps were on the input -maybe 25? Under 30 anyway since it was fused with 30a in Stud 1. Lots of voltage drop in those wires and connections.
Output was 14.1 and house batts 13.8ish, which would be going up over time to 14.7 (at the charger) with amps steady at 18ish in the Tri (so a 2a load +18= 20)
So it works and no amps tapering like with regular 7-pin. (down to 4.6 amps five minutes after starting the truck)
wow, thats quite the loss. where were you measuring the amps, at the truck battery or the camper battery? I m realy surprised with that much voltage drop your not getting a pretty hot wire.
Steve
