jstaffon's avatar
jstaffon
Renogy Solar Panels
I just received my new 100 W Renogy Portable Suitcase. Using the factory default settings except for Celsius to Fahrenheit and time/date changes, I noticed that when I first hook the panels up to my camper both the PV and Battery current starts out at around 6 amps. It holds steady for about 5 minutes or so and then both the PV and Battery current drop off to around 2.5 amps. The voltages are 17 and 14.4 respectively in both cases. When it's drawing 6 amps I can partially shade the panels and see fluctuations in the current. I see those same fluctuations when it shows 2.5 amps. Is there something misconfigured in my controller or is this normal operation? During these tests I saw no changes in the sun location or clouds.
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
