- mlts22Explorer III'd be upgrading almost everything else. I can see lithium batteries useful for vans that cost a quarter of a mill because people are willing to pay the big bucks to have the most bang possible in that small a rig.
However, on my current rig, and even the next motorhome, there will be a lot of other electrical things that need improving before I spend the money for the lithium batteries and their special charge controllers. - MrWizardModerator
Boon Docker wrote:
Ten times the cycles, ten times the cost. Works out to about the same in the long run. ;)
yeah but you got to have the up front money to buy them
a long haul investment you gotta hope pays off
not enough years of documented experience to verify all the claims
and whats the difference between these (for RV/marine use)
and cellphone/laptop etc.. that need replaced after only two years and 700=+ cycles - 2oldmanExplorer II
grizzzman wrote:
A $1200 battery is much more than cells.
Dang I can pick up USA stock 100AH cells for 112.00 each plus shipping
So 448.00 plus shipping. Is a far cry from 1200.00
I'll bite... where you do get these cells? - Boon_DockerExplorer IIITen times the cycles, ten times the cost. Works out to about the same in the long run. ;)
- 100AH lithium = 200AH Lead acid as you really should be using just 50% w/ lead acid.
At 100% DoD lithium goes 3000 to 5000 cycles. Lead acid 300 to 500 cycles. - grizzzmanExplorer
2oldman wrote:
time2roll wrote:
That's not bad.. considering a single 12v 100ah Li runs about $1200.
Tesla Powerwall is 14 kWh for $5,500 or $392 per kWh and includes inverter.
Not exactly outrageous IMO. Scaling this down is the issue.
So 448.00 plus shipping. Is a far cry from 1200.00 - 2oldmanExplorer II
Not exactly outrageous IMO. Scaling this down is the issue. - So a pair of T105 is what $250 with 110 a/h usable or $190 per kWh
Powerwall is just 265 pounds. - Boon_DockerExplorer III^ That sounds about right.
Boon Docker wrote:
He must be looking at motorcycle batteries.
Please give us the link to these inexpensive Li batteries. I would love to pick some up.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
