rjsurfer's avatar
rjsurfer
Renogy Solar thinking about getting into Lithium systems
Just took a small survey from Renogy about current battery setup. They mentioned that they are planning a "new Lithium energy pack" and are looking at present RV battery configurations.
I have been happy with their equipment and customer service so far and would like to see what they come up with.
Ron W
  • wa8yxm wrote:
    Prices are dropping in fact they are now in line with Trojan T-105's and should continue to drop farther.
    Please give us the link to these inexpensive Li batteries. I would love to pick some up.
  • 2oldman wrote:
    And Li batteries get real nasty if not properly charged.
    The Li battery prices I see (for 100ah) are in line with about 10 T-105s. Li batteries will handle being undercharged just fine.
    Agreed, prices are no way near T-105's price range.
    I have 2 years on my 4 T-105's and I don't expect to be replace them lead acid again when they die.
    Ron W
  • There are plenty already using them in Boats.
    Incorporating Automatic low voltage disconnects and high voltage disconnects is where the money adds up. The Individual prismatic cells do not really cast all that much.
    Some use them without such automatic battery monitoring devices, and simply limit charge voltage and duration manually to keep them outside the 'knees'
    What is likely the best thing about them is not needing to reach full charge. Cycling them between 80% and 20% seems to be the best for them.
    One needs to unlearn the lead acid mindset of get them full and keep them full. But so many have never learned that mindset, and simply prefer to complain when their lead acid batteries need replacement.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There is a lot of new and exciting info on the Lithium front.
    However so far only half the technology is there for the most part in the RV world.. The battery itself.. The Chargers are still a bit .. er... rare (As it happens I have one but I do not trust it).
    Now one of my chargers is a Xantrex Prosine 2.0, fully programmable it can be set to charge Lithium batteries of assorted types.. but ... For reasons i would rather not go into I don't trust it (I need more testing before I can comment.
    In fact I don't use it for my Flooded wet cells (I use a Progressive Dynamics Intella-power 9180 with wizard).
    But not many chargers are that programmable.
    That, howevever, is what companies are working on, making them safer and safer and lower and lower in cost.. I expect soon to be changing over myself .
  • The advantages are huge for Lithium, light-long lasting-fast charging, it's only a matter of when to take the plunge as the price is still high.
    I'm on the fence but already planning an install next spring if things work out (I think to keep costs in line you still need to make your own, and while there are kits out there it is not trivial to make your own and the cells are very easy to damage)
  • Probably will be costly but the more companies get into Lithium the better for the consumer.
    Ron W
  • Does Renogy make anything? I thought they sold others stuff.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Jun 06, 2020
