CavalierTwo's avatar
CavalierTwo
Repaired Spring Hanger Brackets: Now What?
First Post On RV.Net.
I recently returned from a round trip to Alaska. Driving 11,444 miles on some of the worst roads in Canada and Alaska. Due to road heaves (from freezing & thawing constantly) creates a real road hazard. I had both rear axle spring hangers break, then replaced and welded. The bummer of it was, I had to have it done a second time. The second time I had reinforcements installed. So 1 1/2" tubing was welded from hanger to hanger on both axles on my 2017 Reflection 26RL 5th wheel.
Now my question: Should I have an inspection on the entire frame, suspension & axle to see if there is other damage?
  • Thanks all for your input. I'll be looking up suspension specialist to get it checked out.
    Thanks Again.
  • Probably worth it if there were multiple issues and had to re-repair some of the fixes.
  • RAS43's avatar
    RAS43
    Explorer III
    Yes,
    I would suggest you find a commercial vehicle repair shop and have them inspect everything and then have the alignment checked/aligned. It is worth the cost IMO.
  • My Tow vehicle is 2015 F250 Powerstroke. My load is around 10K.
    And yes those heaves do sneak up rather quickly.
  • Welcome to the forum.
    Sounds like some of those heaves snuck up on you and you didn't have time to slow up.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 21, 2025
