getpower1's avatar
getpower1
Jack Bracket Mounting Repair
So, I've been thinking about how to deal with an issue for a while, and the short term solution seems simple to me. But I'd like to bring it to you guys and see if you have any other recommendations.
I don't have a lot of time, or insight of camper construction. I just know what's there now and that if like to sturdy it up a bit. Not fully and permanently repair it at this time.
Here's the issue. My truck camper is in my signature below. The four jacks on it are the Reico Titan hydraulic pump models. The passenger side front one seemed a bit loose going on and off the truck. So far, it's only gone on and come off about three times, so my experience level is still very green. But that jack in particular was causing some weird shifting and wobbling.
I checked it out and my first thought was to get scared and I thought, oh no, this corner is rotted. Through all of my research plus with the refrigerator being there and the camper being so old it seemed very possible. When I checked into it and really looked it over closely, I figured out what happened. It looks as if something was hit by a previous owner on that side and scraped against the whole side of the camper. In the process of this happening, it looks like the jack took some pressure from whatever was hit. I say this because it seems like the screws aren't holding on that side like they should be. I've taken a socket and tightened them up as best I could for now and we will see how it does the next time I load the camper. If your familiar with the brackets, it looks like an "L" shaped piece of angle and it's screwed into the corner with about a dozen large sized wood screws.
While tightening, a couple of them felt like they actually weren't biting into any meat.
My obvious temporary fix is to see if I can find some larger, maybe tiny bit longer screws and see if I can crank those in there.
Any experience on this? Any opinions on a fix? Suggestions?
The big, permanent fix would be to pull the thing apart and completely replace the piece of framing in question. It's just not feasible for me to do at this time. Safety being a number one concern, I don't see why a quick repair like I've mentioned would cause any worry. It's not huge damage, and like I said, took a little bit of an investigation to come to the conclusion that I did. But at this time I really have no reason to suspect water damage. The camper is in very good condition and was decently taken care of.
  • Got it! Alright cool. Looks like I've got somewhere to start.
  • I like to completely fill the hole in and start from scratch, and don't really like screwing directly into the epoxy. Large chunks of cured epoxy tend to crack when you screw into them.
    With the dowel, you're screwing into the dowel and the epoxy is holding the dowel into the camper frame.
  • Looked at that git rot product. Seems like a good deal for sure
  • I'll check out that product. The dowel idea is a good one. Didn't even think of that.
    No rust on the screws, but I am positive that there's no rot in that corner. Just some stripped screws. Good thought about not going longer. I know that the construction is 2x2, or at least it was advertised that it was.
    Epoxy is a good idea. Wouldn't that be a decent fix on its own? Something like quick steel. Drill it out some to clean it up, then put the stuff into the holes good. Epoxy would be better because I can inject it. Then I can simply drill some new pilot holes and reinstall the screws. That may be the route I go.
    The screws are not rusty. But that's kind of an irrelevant point because of where I live. At least, I know that the threads aren't rusty.
  • Go to a boat repair shop and get some wood repair products. I used "Git Rot" on mine. I would first inject as much of the liquid into the individual screw holes over multiple applications. This soaks into rotten and semi rotten wood and hardens it up to epoxy like. Finally, soak some dowels and then drill out the holes and epoxy in the dowels, then drill out the dowels for your screws.
    You might even drill a small hole just above the top screw hole, so the seeping can soak into above the first screw hole.
    git Rot
  • If you can verify that the surrounding wood is not rotten, and the holes are just stripped out, drill them out and epoxy some hardwood dowel into the holes to fill them. Then put the bracket back up and drill fresh holes in the dowel.
  • I had to repair my TC corners, an 04 Travel-lite.
    Are the lag bolts rusty? (Indicates rot)
    Don't go longer as you may penitrate the interior, larger ok but make sure that they go in straight, again watch the interior. Most walls/corners are 3/4" to 1.5" thick.
    Others have fabricated a metal corner larger than the jack bracket to find good wood and used lots of small screws.
    Good luck.
