TriumphGuy
Oct 05, 2015Explorer
bdpreece wrote:
I have seen where people are using door kick plates You can cut them to size and screw/glue in place. You need to make sure that the bottom is failing because of weight rather than a leak that caused it to fail before doing the repair.
Great tip! Thank you - I was about to order some plate material online but that's a better approach.
I'm 99% sure there isn't a leak involved but I'll triple check. Should be pretty darn obvious since we just had rainmageddon here...
