phemens
Jun 05, 2020Explorer
BFL13 wrote:
Recently installed a second hand Norcold 6xx to replace the 1991 OEM Dometic that rusted out. Can't answer your question, but note the size of your RV doorway too. You can't necessarily put the fridge through by its narrowest aspect. Fridge door is one "issue".
I had to take the whole RV door, frame and all, out of the RV to get the fridges out and in, and it was very tight at that. Once in, it was another struggle to get the fridge in place. Took all day with son's help.
You have to figure it all out before getting the one out through the RV door, which way it should be oriented, and then the new one in so it can be put into its slot. One of those IQ tests you don't want to fail :(
I have a very large window opposite the fridge in the slide, plan would be to remove it to do the swap (I have to reseal all the windows at some point anyway, so a good excuse)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
