agesilaus
May 04, 2020Explorer III
Why can't you simply disconnect the PEX tubing and reconnect it when done. As for the flex I assume vinyl tubing that's asking for leaks. If you must carefully cut the PEX hose, get a PEX splice from the hardware store and just splice the PEX back together. I had a number of leaks from the manufacturer using vinyl tubing where PEX was called for.
Sharkbite spilce
Sharkbite spilce
