rexlion's avatar
rexlion
replace RV entrance door hinges?
My trailer's entrance door is sagging. The hinges are worn out. I use this trailer to haul cargo daily for work, and I estimate that the door has been opened and closed upwards of 40,000 times.
How hard is it to replace these hinges? Or am I better off buying a new door/frame assembly?
It looks like the hinges might be riveted to the frame, but I'm not sure if those are rivets or something else. They screw to the door, so that part is easy enough to detach.
  • jdc1's avatar
    jdc1
    Explorer II
    All you have to do is drill out the rivets. The rest is easy, if you have a helper. But, you might try adding rivets where needed instead of tearing anything apart.
