ScottnSherrie
Dec 13, 2014Explorer
dougrainer wrote:
RV Entry doors on Towables are NOT like residential doors or any other type doors. The ONLY way to fix the problem you described is to replace the COMPLETE door assembly. On Towables, you just remove the outside screw cover and remove the mount screws and any inside valance or other equipment mounted to the inside frame. PULL the old door and REMEMBER to NOT OPEN THE NEW DOOR AT ALL, INSTALL IT AS IT WAS SHIPPED. If you open the new door before installing you will have the alignment shims fall out and your new door will not be square and operate correctly. Even under warranty, we replace the complete door assbly for bent or incorrect install from the factory. Doug
Replaced the door on The Old Gal a few years ago. Had to custom order as it was an odd size. Ditto on the above.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
