CA_Traveler
Jan 02, 2021Explorer III
Gottahaveit wrote:Are you sure the polarity is correct? Lights will work even LEDs with the polarity circuit, DC motors will run backwards. But electronics not so much.
Ok we can get everything to work off the batteries until I turn on the inverter then a click and everything shuts down.
A $10 voltmeter from HF with the black wire connected to frame ground can help...
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
