MrWizard
Jan 04, 2021Moderator
Is this an Inverter_charger combo unit, or separate stand alone inverter,
Does inverter supply 120vac to the whole RV or just a few dedicated circuits
If this a Separate inverter powering the whole RV,
Do you have any portable electric heaters plugged in, anything that could be drawing a really high amp (power watts) load on the inverter
My ,2000w inverter pure sinewave inverter, will run my MW, powerMax 75 amp converter, or a portable electric heater, but not enough batteries for a long run, voltage Drop means high amps, which heats up the DC circuit breaker , then it trips,
I only forgot and did the electric heater on inverter battery power ONE time, that was enough, I have forgot to turn off the converter power circuit several times, when switching from generator to invereter here, in this Bounder, the Safari was wired with only dedicated circuits kitchen and entertainment to inverter,
I installed this inverter, here in the Bounder, and connected it to power all outlets etc..
Power going to converter must be shut off before turning on inverter, if I forget to turn off circuit breaker for my 75 amp converter when switching from generator to inverter,
After a about 20 minutes the DC amps load feeding the inverter to . Power the converter from the inverter THE breaker will be hot and trip,
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
