Gottahaveit
Jan 04, 2021Moderator
UPDATE: After checking everything over and over we still could not get the inverter stay running. On one final check of power hooked the ground cable up to the large bolt under the the key switch that shuts off the ground to the batteries and wham inverter turns on lights in cabinet come on etc. Yes the ground key switch was not making a good contact :S We are back and running properly and will be headed to AZ next week !!
Thank you for trying to help.
(George it's the all in one Magnum inverter. Yep I've turned on the hair dryer with a heater running at the same time LOL Pop goes the fuse) Miss seeing you in Q.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
