Vintage465's avatar
Jun 04, 2022
Replaced WFCO with PD
So, I've been somewhat living in my 2015 ORV 20fq for the last week or so and the existing WFCO converter was surging/spiking on the 12v side, so I retrofitted it with a new Progressive Dynamics with the charge wizard. This was the kit that just replaced the converter but not the whole load center. Installation was super easy and went exactly according to the instructions. I like for liked it at 55amp charging. It just barely accepted my #4 wire for charge line to the batteries. I'll need to read up on the Charge Wizard to see if I want to switch it on. I assume there is a switch for on and off in the event you don't have flooded batteries..........
  • I have a PD4635 that I just installed a couple weeks ago. It does have a button on the board and I also got the pendent. I can't figure out how to install the pendent, but if I take the faceplate off the original WFCO unit, then you can access the switch. It's on the PCB that holds the fuses.
    There is also a way to use this converter with Li batteries.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Vintage465 wrote:
    I have four 6v flooded old school golf cart batteries. I read up on the manual. What it actually says is there is a button you can push on the circuit board to "arrest" it(they don't recommend doing this) in what ever stage you like. Then after some event...like the end of the stage/cycle, it will default back to the algorithm........anyway, I don't see why I'd do that, but that's the way I read it.
    I read the Wizard manual a bit differently but the effect (end result) is the same.
    I do not recall seeing a LiFePO4 mode but they did enter into a deal with Battle Born to produce a converter for LiFePO4s and they may have added that mode to the wizard since (Would make sense to do so)
    No matter what model you have no matter if wizard is built in Like 4600 or 9200 or plugged in (9100 which I had) same wizard.
    Those with built in have an optional dongle. That's where the button is.
  • The PD unit I bought has the pendant where you can choose which mode to put the unit in if you choose, also has an option for lipo if I ever go that route.
  • wa8yxm wrote:
    To my knowledge there is NOT a switch to turn it on/off
    But what batteries do you have.. if they are lead acid.
    Flood or Valve regulated sealed.. Sloshing wet (maintenance free) or "Starved" (AGM) the voltages are all dang close so it should not matter.
    LiFePO4 Contact Progressive Dynamics.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Oct 07, 2025
