philh's avatar
philh
Explorer III
Mar 06, 2019
Replacement Battery Charger / Power Station
More knowledge is a good thing???
New TT, haven't looked at the charger brand installed, but suspect it's the cheap one that doesn't fully charge. I measured voltage two days after it had been disconnect from house 120V, the single 12v battery was shut off from TT, and the voltage measure 12.1v!
Thanks to RV.NET, I've learned the charger doesn't fully charge.
Assuming I'm going to replace the unit to charge (2) 6v batteries, what unit should I be looking at. TT is 22' and has 30a AC circuit. Not sure the number of DC circuits.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Go for a Progressive Dynamcs
    If the coverter is stand alone or you wish to keep current one as a "Back up" 9200 line If the converter is attached to the power distribution box. 4600
  • Buy an inverter/charger, this prepares you for the day you decide to add solar panels.
  • Gjac's avatar
    Gjac
    Explorer III
    I would go with a stand alone as the previous poster suggested. I bought the 40 amp B&D charger and it does a good job on 2 6 v GC batteries. It has an equalize function at 15+ volts and a desulfating function. I don’t think any of the newer “smart chargers” completely charge your batteries. I use my onboard constant charger to complete the charge and to maintain the batteries. If you don’t have more than 1 or 2 batteries it is a cost effective way of charging and maintaining your batteries. How long did you charge your batteries when you read 12.1 v? Even old or inexpensive charger / converters will charge your batteries if they are good.
  • You can change the converter,
    or,
    you can get a stand alone charger to connect to the batteries directly.
    The built in converters, WFCO etc are not great, most on here seem to prefer the Progressive Dynamics and others for when their WFCO unit fails, but instead of changing out the unit you can use a secondary charger.
    Just depends on time, effort, money, convenience and which is higher on the decision priorities for you.
    One advantage to consider though for the standalone charger is that many have the "Boost" or jumpstart feature which is also useful for your tow vehicle as well as giving you a charger for other purposes.
    Also if you are adding solar, that may become your higher voltage charging method.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
