SJ-Chris's avatar
SJ-Chris
Explorer II
Sep 13, 2018
Replacement compartment latch / rekey? Items stolen?
Hi All,
All of my external storage compartments have locks that are opened/locked with one key EXCEPT for one compartment (ugh). This forces me to have two different keys. I would like to convert the one odd-ball latch to one that will work with the key that is used on all the others.
Does anyone know if a locksmith can convert the one odd-ball latch to work with the same key as all the others? Or is there a micro-stamp part# somewhere on these latches that would tell me which replacement latch I could order?
Let me know. Thanks!
Not that it should matter on this issue, but this is for a 2008 Four Winds 31p Chateau Class C RV.
I did google and find out that a huge percentage of these RV compartment latches are opened by the SAME key...meaning that if people wanted to open up your compartments there's a decent chance they can do it with one of their keys. How many of you have gone and changed ALL your external compartments to a different/unique key? I found this place online: ch751.com
Have any of you had stuff stolen from your external compartments (...likely because so many others have your same key??)? Just curious.
Thanks!
-Chris
  • Instead of using the genearic 751 key why not buy some of the barrel locks and replace everything. Barrel locks are readily available on places like Amazon and large RV parts stores. Probably wont cost you any more than rekeying a bunch of locks.
  • I have replaced all of mine just like those on my 2006 Tioga with These ,they can all be keyed alike so I only have one key for everything. Just pick the size and how many you want.
    I also like that they have a cover on the key slot that moves when you insert the key,thus keeping all grime out.
Having RV issues? Connect with others who have been in your shoes.24,342 PostsLatest Activity: Dec 05, 2025
