doughere
Apr 30, 2013Explorer
I have a PD9260 leave it plugged in all the time at home, maintains the battery fine (two 6V GC are now 6 years old with no apparent loss of capacity). We dry camp often, and the unit has great output when recharging from gen.
The 9260 replaced the original 45 Amp single voltage converter installed in the power center(actually left original in place as an emergency backup). Required installing unit in a different location. I moved it from the original power center where it was too big to mount to a compartment next to the batteries. Used battery cables from a local automotive store to wire the system from the converter to the batteries to essentially eliminate any voltage drop between the converter and batteries. Extremely happy with the results.
Doug
Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
